Cannot redeclare class WA_MySQLi_RS
Thread began 2/09/2020 2:49 am by georgina_barrett_187762 | Last modified 2/10/2020 8:19 am by Ray Borduin | 88 views | 1 replies |
I have having some strange issue on one of my new siites. I can add a recordset ok but then if I add another recordset on the same page I get this error Fatal error: Cannot redeclare class WA_MySQLi_RS in /home/ ........ .co.uk/webassist/mysqli/rsobj.php on line 3.
Ittdoesn't matter that recordsets they are - or what tables I try and pull data from. It works with one recordset but not with 2
Additionally I am getting an error on an update page
Fatal error: Call to undefined method WA_MySQLi_RS::Prepare() in /home/. .........co.uk/webassist/mysqli/queryobj.php on line 480
I cannot work out why. They are both very basic scripts.
I have attached the 2 pages
Did you change your site root? It looks like you have:
<?php require_once('../../webassist/mysqli/rsobj.php'); ?>
require_once('../webassist/mysqli/rsobj.php'); ?>
My guess is an updated site root caused the reference to be repeated. You only need one of those (the one that is in the root of the site)
The Prepare() error is probably a bad connection. The details page uses a connection in the folder:
<?php require_once('../../Connections/funnel.php'); ?>
but the update page uses:
<?php require_once('../Connections/funnel.php'); ?>
My guess is that the connection information is different (wrong) in the update page version.
