Error after update Data Bridge
Thread began 1/29/2020 1:01 pm by john70964 | Last modified 1/31/2020 6:43 pm by Ray Borduin | 172 views | 5 replies |
john70964
Hi Ray
I am getting this error after updating the mysqli recordset
Parse error: syntax error, unexpected '&&' (T_BOOLEAN_AND) in /homepages/37/d415519235/htdocs/net100test/consul/update_results.php on line 13
I wondered if you could see what is incorrect?
I am attaching the file.
Many Thanks
John
There are some mismatched parenthesis on that line:
You have:
if (isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"])
it should be:
if (isset($_POST["WADbSearch1"]) && ($_POST["WADbSearch1"]))
john70964
Thanks Ray
I updated another page and received another error message
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in /homepages/37/d415519235/htdocs/net100test/consul/update_boats.php:60 Stack trace: #0 {main} thrown in /homepages/37/d415519235/htdocs/net100test/consul/update_boats.php on line 60
I have attached the page.
That error is because you are using php7 which doesn't support standard MySQL. You will need to update your Database Update server behavior to use MySQLi on this page. It is still using the old MySQL version.
john70964
Thanks Ray,
As far as I can see all of the server behaviours are showing MySQLi recordsets etc.
Can you please say what else needs to be done?
Many thanks
John
When I open your attached page I see an "Update Record" server behavior that hasn't been updated to "MySQLi Update Record" yet.
