I'm building an eCommerce website but am having issues with my registration/ login pages not showing up when I put my site live
Thread began 11/20/2019 12:33 pm by Bill | Last modified 11/22/2019 9:15 am by Ray Borduin | 631 views | 5 replies |
Bill
Everything works well on localhost, but when I put my site live both the Registration and login pages won't display'
My site can be found at www.pmsites.com
This usually happens when you don't upload some of the necessary include files. Maybe the connection or one of the other library files. If you add this code to the top of the page it might give you more information:
ini_set
("display_errors",1);
Bill
Thanks Ray I ran the code and I got this:
ini_set("display_errors",1);
I've updated the code example... The code needs to be in php tags.
Bill
Ok thanks Ray now I've got
Warning: mysql_pconnect(): Access denied for user 'root'@'localhost' (using password: NO) in /home/posi0622/public_html/pmsites.com/Connections/MySQLDatabasde.php on line 9
Fatal error: Access denied for user 'root'@'localhost' (using password: NO) in /home/posi0622/public_html/pmsites.com/Connections/MySQLDatabasde.php on line 9
That means your database connection information is wrong for the live site. You should check your connection file to make sure you are using the correct server, username, password, and database name for the live site.
