Deletion of security question needed please
Thread began 9/17/2009 6:22 am by paulmgillard360368 | Last modified 9/21/2009 3:37 pm by paulmgillard360368 | 7776 views | 4 replies |
paulmgillard360368
Hi support
Here is the page I have the form on:
contactus.php
My customer doesn't want the security question on the form (nor the captcha which is removed as you can see).
So, how can I remove the security question now please?
Plus if I want to add any kind of other field into the form like a tick box how can I do this?
The level of automation on this whole product should be rated as 1 out of 100 because you have to bury your head in code to make small changes. It should be a 'menu-driven' product rather than a 'Geeky Techno Head' code-thing. (a great pity)
Paul (graphic designer)
www.pgmedia.co.uk
contactus.php.zip
In the how to section of the Contact Form Solution pack support page, there are two tutorials that will help you with this:
1) "How to remove security features from your Contact Form"
2) "How to insert additional form fields to your Contact Form"
paulmgillard360368
getting there
Hi Jason
Thanks for your help! I managed to do that bit OK now.
I'm preparing a page where people can simply click to be added to the mailing list:
mailing_list.php
But now the submit button doesn't work unfortunately.. Please advise.
Cheers
Paul
ps: I enclose an error message (error-1 .jpeg) which warns me about something. What should I do about that please?
Since you have removed everything but the name and email address fields, you need to remove the validation for all of the fiedls tha twhere deleted.
In the original contact form soulution pack, the valiation code looked like:
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect "";
$_SESSION['WAVT_contact_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
You need to change it to:
$WAFV_Redirect "";
  if (
$WAFV_Errors "";
  if (
For the Dreamweaver error, delete these two lines of code:
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:5, maxChars:5});
paulmgillard360368
Fantastic job. Thank you.
Hiya Jason
That all works perfectly now, thank you very much!
I'm really pleased and so is my client.
mailing_list.php
Best regards
Paul
www.artistsindevon.com
