Errors on intallation
Thread began 9/15/2009 11:25 pm by jebrandon343719 | Last modified 9/16/2009 9:28 am by Jason Byrnes | 1090 views | 1 replies |
jebrandon343719
I am getting errors when the Extension manager is instlling e-cart. In fact I get the same errors if i try to uninstall. I have had the extension for 12 months now.
The error(s) are suggesting that Dreamwaever is open. I am asked to close DW - I havent got DW open.
There are many but here is one
The file 'C:....\eCart\Shipping\WAeCartFedEx.htm' is beging used by Dreamweaver.
Sometimes its a file in the /server behavious/ folder ??
I have tried removing the offending files, etc but nothing. Now I am stuck - cannot install and cannot uninstall.
your configuration folder may have become corrupted. You can rename the configuration folder to have Dreamweaver recreate it. Close Dreamweaver and go to:
WinXP
-DW8
--C:\Documents and Settings\<Your User Name>\Application Data\Macromedia\Dreamweaver 8
-DWCS3
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver 9
-DWCS4
--C:\Documents and Settings\<Your User Name>\Application Data\Adobe\Dreamweaver CS4\en_US
Win Vista
-DW8
--C:\Users\<Your User Name>\AppData\Roaming\Macromedia\Dreamweaver 8
-DWCS3
--C:Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver 9
-DWCS4
--C:\Users\<Your User Name>\AppData\Roaming\Adobe\Dreamweaver CS4\en_US
Mac OSX;
-DW8
--Hard disk: Users: <Your User Name>: Library: Application Support: Macromedia: Dreamweaver 8
-DWCS3
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9
-DWCS4
--Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver CS4: en_US
(Please note that <Your User Name> Should be replaced with the User name you use to log into your computer)
Rename the configuration folder to configuration_back. This will have the effect of disabling all of the installed extensions. You should open the extension manager and remove all extensions to clear the extension mangers cache. After removing the extensions you can then reinstall them making sure to download the latest versions from your order history.
NOTE:
On Windows Computers, The AppData or Application Data folders may be set to be hidden.
To View Hidden Folders in Windows Vista:
1) In The Windows Explorer, Click the "Organize" button
2) Select "Folders And Search Options"
3) Select the "View" tab
4) Click the "Show Hidden Folders And Files" radio button.
To View Hidden Folders in Windows XP:
1) On the Tools menu in Windows Explorer, click Folder Options.
2)Click the View tab.
3) Under Hidden files and folders, click Show hidden files and folders.
