No results from admin product ID search
Thread began 6/10/2019 2:25 pm by tmcbinc99963 | Last modified 6/11/2019 9:22 am by Ray Borduin | 206 views | 1 replies |
tmcbinc99963
An admin search returns no results from the ProdNum column.
Previously it showed all results except for the first 6 rows of the Db. When trying to fix that error, it now shows no results.
The other search fields show correct results for all records except the first 6 rows.
This happens in both the prod_search.php and prod_results.php search forms, which leads me to think it's a Db error. However, I don't see anything that could be causing the issue.
The parameter shows up in the URL correctly.
You had your search set up to search the ID column not the ProdNum column, so there was no ID of 201. I updated your prod_results.php page to search on the ProdNum column instead and now it returns a result.
