Drop Down Menu Problem
On the home page only, the drop-down menu disappears as soon as the cursor moves to select an option. On the rest of the content pages it displays properly.
How do I fix this?
How do I fix this?
I am also having this same issue. It only hapens on the index.php page
can you post a link to the index page so I can investigate the problem, it is likely something in the css.
This issue only occurs in IE 7 and is also an issue in the Powerstore Demo.
At the top of the index.php change the following code:
@import url("css/common.css");
#outerWrapper #navWrapper {
padding-bottom:0px;
z-index:999;
to
padding-bottom:8px;
z-index:999;
Just change the padding-bottom from 0px to 8px
Hope that helps. If it still goes away you can go up to 10px
