Dynamic chart from URL variable
Thread began 9/14/2009 10:02 am by admin388558 | Last modified 9/14/2009 3:16 pm by Jason Byrnes | 1844 views | 1 replies |
admin388558
Hi I'm trying to populate a chart with dynamic data based on a URL variable i.e.
http://www.myDomain.com/sompage.php?treeId="here is my variable"
I'm not exactly sure how to do this I noticed that there is a method for this but I am not sure how to tie it all together if maybe you could give me some instructions or point me to a tutorial thanks
I do know that there is a drop down list for filtering which allows you to set some parameters to either Session Variable or URl parameter but how do you make it work??
thanks again
Above t5he filtering Select list is a list to select the database column you wish to compare, select the desired column, then select the URL Variable option in the filtering select list. In th box next to the filtering select list enter "treeId" to tell it you are using the treeId URL variable.
