Dropdowns get background from parent website
Thread begun 9/14/2009 7:19 am by jon_upton | Last modified 9/14/2009 4:53 pm by Jason Byrnes | 2327 views | 2 replies |
jon_upton
Hi
Dropdown boxes from the irite menu display the same background as the front end website - the css used in front end is not present in the backend page.
See image
Site address is www.sbcw.co.uk If contacted directly I can furnish a username and password to enable looking at actual irite screen
Cheers
Jon
jon_upton
I've worked this one out but..
I think its still an error
I have linked to my css file to make my styles available
I have a single style sheet with all my settings in and irite seems to add the page background set in the css to the dropdowns.
I've unlinked for now I guess I could have multiple style sheets to overcome this but I like to have a single stylesheet so it is easy to find everything
regards
Jon
If you use multiple style sheets, do you still have the problem?
If not, make sure the Styles being used by iRite are listed near the bottom of your css file so that they can over ride the styles higher up in the page.
If you could put together a sample page with just iRite on it for troubleshooting, it would help us get to the bottom of the issue pretty quick.
