Warning: session_start() error message with file upload form
Thread began 9/14/2009 4:36 am by terry370125 | Last modified 9/14/2009 3:01 pm by Jason Byrnes | 1888 views | 3 replies |
terry370125
With DFP2, I have a very simply upload form, which is intended to upload to a /Downloads/ folder that is outside the web root. When I attempt to upload a file, the following errors are shown.
Notice: Use of undefined constant on - assumed 'on' in E:\webs\lsmontgomery.com\wwwroot\uploadDownload.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at E:\webs\lsmontgomery.com\wwwroot\uploadDownload.php:3) in E:\webs\lsmontgomery.com\wwwroot\WA_DigitalFilePro\HelperPHP.php on line 70
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at E:\webs\lsmontgomery.com\wwwroot\uploadDownload.php:3) in E:\webs\lsmontgomery.com\wwwroot\WA_DigitalFilePro\HelperPHP.php on line 70
I included the code, <?php error_reporting(E_ALL); ini_set('display_errors',on); ?> at the top of the page and <?php echo WA_DFP_AllUploadsDebug(); ?> at the bottom of the page in an attempt to debug the page. This gave me the following listing:
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName : images/spacer.gif
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
WHEN I REMOVED THE DEBUGGING CODE, the following error messages appeared.
Warning: mkdir() [function.mkdir]: Permission denied in E:\webs\lsmontgomery.com\wwwroot\WA_DigitalFilePro\HelperPHP.php on line 30
Warning: move_uploaded_file(E:\webs\lsmontgomery.com\wwwroot\..\..\downloads\454b08a5fa82b1c3595b76aee7c0f477_tmp.jpg) [function.move-uploaded-file]: failed to open stream: No such file or directory in E:\webs\lsmontgomery.com\wwwroot\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move 'D:\temp\PHP-uploads\php2D81.tmp' to 'E:\webs\lsmontgomery.com\wwwroot\..\..\downloads\454b08a5fa82b1c3595b76aee7c0f477_tmp.jpg' in E:\webs\lsmontgomery.com\wwwroot\WA_DigitalFilePro\HelperPHP.php on line 96
Warning: copy(E:\webs\lsmontgomery.com\wwwroot\..\..\downloads\454b08a5fa82b1c3595b76aee7c0f477_tmp.jpg) [function.copy]: failed to open stream: No such file or directory in E:\webs\lsmontgomery.com\wwwroot\WA_DigitalFilePro\HelperPHP.php on line 98
I have contacted my web host about permissions for this folder. He tells me that the /downloads/ folder has read/write access.
Any help you can give me in debugging this problem would be very much appreciated.
Best regards,
Terry Montgomery
looking closely at the error message, it is trying to move the uploaded fiile to:
This location translates to:
E:\webs\downloads which does not have the propper permision.
Most likely you have the uploads folder set as "../../downloads/" try setting it as "downloads/ so that the uploaded file will go to:
E:\webs\lsmontgomery.com\wwwroot\downloads\
The dubuging code should be:
Not including the single quotes around on was causing the errors you where getting.
terry370125
Warning session_start()message with file upload form
Thanks! Your advise helped to fix the problem. I was attempting to upload files to the "downloads" folder outside the web root. When you go through the DFP2 wizard and point to that folder outside the web root, the resulting code from the wizard is "../../downloads/". After reading your solution, I changed the UploadFolder to "../downloads/" and it now works fine.
Much appreciated!
Terry
You're welcome.
