Menu under Web Ad
On our site we have we ads. However when the drop down menu is show it is UNDER the Web ad.
see SafetyProgram.htm for the drop downs that do not work.
How can I correct that?
Open your menu.css file and look for this class definition:
ul#cssmw1 and add this two properties:
position:absolute;
z-index:100;
so it should something like this:
ul#cssmw1 {
cursor:default;
list-style-type:none;
margin:0;
padding:0;
position:absolute;
z-index:100;
Thank you that worked like a charm HOWEVER the cssMenuwriter is then disconnected from the menu. When I do re-connect I have to re-input that change. Is there ANY WAY for the change to be saved so that everytime I go back to the CSS MenuWriter it says in place.
Or that not being the case have the drop down have those set that way all the time?
I put the change into the menu.css but when I do that I then am DISCONNECTED from CSS MENU WRITER. How do I get re-connected? Or still yet why not generate the code so that the user has th option to have the menus be on top?
In order to save the changes, you will need to update the xml file for that menu. In order to do that, open the menuStyle.xml file which is located in this folder:
CSSMenuWriter/cssmw1/menuStyle.xml
In the top of that file you should see an entry that look something like this:
<list-style-type>none</list-style-type>
<margin-top>0</margin-top>
<margin-right>0</margin-right>
<margin-bottom>0</margin-bottom>
<margin-left>0</margin-left>
<padding-top>0</padding-top>
<padding-right>0</padding-right>
<padding-bottom>0</padding-bottom>
<padding-left>0</padding-left>
<cursor>default</cursor>
<font-size>0</font-size>
and you should add the two changes, so it should look like this:
<position>absolute</position>
<z-index>1000</z-index>
This will ensure that changes stays after you reenter Menu Writer.
