Tabs overlapping
Thread began 9/11/2009 2:49 pm by esther379760 | Last modified 9/11/2009 5:27 pm by Dani Chankhour | 1876 views | 3 replies |
esther379760
Tabs overlapping
hi Jason,
I posted this as a reply in my previous post, but not sure you'll go back there to see it.
When mousing over Our Team, the main level is perfect, but then the second and first overlap each other and it gets real confusing. what am I doing wrong? THANK YOU!
tami.html
Also, is there a way we can set preferences so that we're notified via email when a reply is posted to your question?
Thanks!!!
Dani Chankhour
You will just need to adjust the left property on the second level. If you open the menu.css file and look for this class definition:
ul#cssmw5 ul.level-2 {
left:112px;
and then try to change the left property until the second level shows correctly.
esther379760
Thanks!
thank you! For the future, is there a way I could have done it thru the design end?
Dani Chankhour
usually after adjusting a width of menu, the second level menu should adjust accordingly. but sometimes (like in your case), you will have to make the change manually.
You could also try changing the margin on the box tab which might solve the issue as well.
