API Authentication using headers
Thread began 4/25/2019 5:46 am by anonymous | Last modified 4/30/2019 10:56 am by Ray Borduin | 1345 views | 14 replies |
anonymous
I am trying to create an API where the username and password is passed thru headers to authenticate. This is the code that I have and it seems to error out each time. Any advice on what I am doing wrong? Thanks
<?php require_once('Connections/sdpc_i.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
if ("" == "") {
$Authenticate = new WA_MySQLi_Auth($sdpc_i);
$Authenticate->Action = "authenticate";
$Authenticate->Name = "sdpc_login";
$Authenticate->Table = "users";
$Authenticate->addFilter("username", "=", "s", "".((isset($_SERVER["HTTP_USERNAME"]))?$_SERVER["HTTP_USERNAME"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".(isset($_SERVER['HTTP_PASSWORD'])?sha1($_SERVER['HTTP_PASSWORD']):"") ."");
$Authenticate->storeResult("username",'username');
$Authenticate->AutoReturn = false;
$SuccessRedirect = "read2.php?page=1&verify=T";
$FailedRedirect = "error.php";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
I think the correct $_SERVER variables are:
$_SERVER["PHP_AUTH_USER"]
and
$_SERVER["PHP_AUTH_PW"]
anonymous
Hmm. Still doesn't seem to authenticate.
Write the values to the page to see if they are set correctly... just add this to the top:
var_dump
($_SERVER);
die();
That will tell you if the header values are set to what you think they are and may shed light on why it isn't working.
anonymous
The username is set to HTTP_USERNAME and the password is set to HTTP_PASSWORD which is what I originally had it set to. The url of the page is https://sdpc.a4l.org/read_test2.php.
Are the values passed to the page present in the database? How are you setting the header variables? How are you passing them in?
anonymous
They are present in the database and I was using Postman to test it where I defined the headers for them.
Perhaps you can't set session variables when posting through postman? The authenticate server behavior relies on session variables to maintain login status and information.
anonymous
Ok. I will look further into this to see. Thank you.
anonymous
If postman does support retaining the session variables. Then when a person authenticates, they would get redirected to this page with restricted access:
<?php require_once('webassist/mysqli/rsobj.php');
error_reporting(E_ALL);
ini_set('display_errors', 1);?>
if ("" == "") {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "sdpc_login";
$RestricAccessRedirect = "error.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
include_once("db_connect.php");
$page = 1;
if(!empty($_GET['page'])) {
$page = filter_input(INPUT_GET, 'page', FILTER_VALIDATE_INT);
if(false === $page) {
$page = 1;
$items_per_page = 50;
$offset = ($page - 1) * 50;
$sql2 = "SELECT *, t1.districtID as thedistrict, t1.statusID as statusID_final, t1.agreement_typesID as agtype from ((SELECT dataID, districtID, softwareID, agreement_typesID, signed_agreement_file, statusID, date_approved, date_expired, year, grade_level, content_area, declined_reasoning, originator, data.softwareID as code1, data.districtID as code FROM data) t1 JOIN (Select districtID, district_name, state, account_status, tec_member from districts) t9 on (t1.code = t9.districtID) LEFT JOIN (SELECT *, addendums_data.addendumID as selected_addendum FROM addendums_data) t2 On (t1.dataID = t2.dataID) LEFT JOIN (SELECT * from addendums) t7 on (t2.addendumID = t7.addendumID) LEFT JOIN (Select agreement_typesID, public, agreement_name, state from agreement_types) t4 on (t1.agreement_typesID = t4.agreement_typesID) LEFT JOIN (Select * from status) t5 on (t1.statusID = t5.statusID) LEFT JOIN (SELECT district_data_elements.districtID as code3, district_data_elements.softwareID as code2, GROUP_CONCAT(element_name SEPARATOR ', ') as data_list from district_data_elements LEFT JOIN data_elements on data_elements.data_elementID = district_data_elements.data_elementID GROUP BY district_data_elements.softwareID) t3 On (t1.code1 = t3.code2) LEFT JOIN (SELECT softwareID, company_name,software_name from software) t6 on (t1.code1 = t6.softwareID)) Where (t5.public = 'Yes' or t4.public = 'Yes') GROUP by t1.dataID ORDER BY t9.district_name ASC";
$result = mysqli_query($conn, $sql2) or die("database error:". mysqli_error($conn));
if(false === $result) {
throw new Exception('Query failed with: ' . mysqli_error());
} else {
$row_count = mysqli_num_rows($result);
// free the result set as you don't need it anymore
mysqli_free_result($result);
$page_count = 0;
if (0 === $row_count) {
// maybe show some error since there is nothing in your table
} else {
// determine page_count
$page_count = (int)ceil($row_count / $items_per_page);
// double check that request page is in range
if($page > $page_count) {
// error to user, maybe set page to 1
$page = 1;
header("Content-Type:application/json");
if ("".($_GET['verify']) ."" == "T") { // WebAssist Show If
$state=$_GET['verify'];
$items = getItems($state, $conn);
if(empty($items) and "".($_GET['verify']) ."" == "T") {
jsonResponse(200,"There is no data found.",NULL);
} else {
jsonResponse(200,"Data Found",$items);
} else {
jsonResponse(400,"This is an Invalid Request or the url has not been verified correctly",NULL);
function jsonResponse($status,$status_message,$data) {
header("HTTP/1.1 ".$status_message);
$response['status']=$status;
$response['status_message']=$status_message;
$response['data']=$data;
$json_response = json_encode($response);
echo $json_response;
// set the number of items to display per page
function getItems($state, $conn) {
// determine page number from $_GET
$page = 1;
$page = 1;
$sql = "SELECT *, t1.districtID as thedistrict, t1.statusID as statusID_final, t1.agreement_typesID as agtype from ((SELECT dataID, districtID, softwareID, agreement_typesID, signed_agreement_file, statusID, date_approved, date_expired, year, grade_level, content_area, declined_reasoning, originator, data.softwareID as code1, data.districtID as code FROM data) t1 JOIN (Select districtID, district_name, state, account_status, tec_member from districts) t9 on (t1.code = t9.districtID) LEFT JOIN (SELECT *, addendums_data.addendumID as selected_addendum FROM addendums_data) t2 On (t1.dataID = t2.dataID) LEFT JOIN (SELECT * from addendums) t7 on (t2.addendumID = t7.addendumID) LEFT JOIN (Select agreement_typesID, public, agreement_name, state from agreement_types) t4 on (t1.agreement_typesID = t4.agreement_typesID) LEFT JOIN (Select * from status) t5 on (t1.statusID = t5.statusID) LEFT JOIN (SELECT district_data_elements.districtID as code3, district_data_elements.softwareID as code2, GROUP_CONCAT(element_name SEPARATOR ', ') as data_list from district_data_elements LEFT JOIN data_elements on data_elements.data_elementID = district_data_elements.data_elementID GROUP BY district_data_elements.softwareID) t3 On (t1.code1 = t3.code2) LEFT JOIN (SELECT softwareID, company_name,software_name from software) t6 on (t1.code1 = t6.softwareID)) Where (t5.public = 'Yes' or t4.public = 'Yes') GROUP by t1.dataID ORDER BY t9.district_name ASC LIMIT " . $offset . "," . $items_per_page;"";
$resultset = mysqli_query($conn, $sql) or die("database error:". mysqli_error($conn));
$data = array();
while( $rows = mysqli_fetch_assoc($resultset) ) {
$data[] = $rows;
return $data;
Does this code look right to recognize the authentication? Or do I need to add something like: $_SESSION[“sdpc_login”] = $Username
