Opencart Products table won't work with the MySqli insert, update or delete.
Thread began 3/22/2019 5:40 pm by James | Last modified 3/22/2019 5:48 pm by Ray Borduin | 222 views | 1 replies |
James
Hi. I am having an issue when trying to use this program to insert, delete or update a record in the supplied database table.
This is a table from Opencart.
I am trying to add a record using this and I get an error then everything breaks and I have to restart dreamweaver.
Not sure what the issue is or if you have ever seen this, but I wanted to bring it to your attention so you can fix the error and I can resume doing what I was trying to accomplish with my favorite Dreamweaver tool!
Thanks!
oc_product.sql.zip
The issue is with having a column named "length". Just rename that column in the database and it should fix the problem.
