Upload Local Database Project to Live Web Server Environment
Thread began 3/18/2019 1:25 pm by admin394099 | Last modified 3/18/2019 2:10 pm by Ray Borduin | 17 views | 1 replies |
admin394099
Thank you for your help, your software takes a lot of pain out of PHP development.
I have a local Database Search project created with DataBridge that is currently working as I would like it here on my local machine. I would like to deploy it to a live Web Server environment & am not sure of the steps associated with this. As a first step I have uploaded the SQL database to the Web Server version of PHP myAdmin, that is in place correctly. My project consists of a simple Search & Results page, which are connected to a connections.php file - I would assume I need to add the server database info to this file & should do so via the Additional Connections of Database Connections Interface.
It is somewhat confusing to me as currently my local Dreamweaver Site Setup has both Local & Remote connection info pointing at my local development folder. I would think I would need to redirect the remote server info to my live environment.
Thanks.
All you have to do is:
1) FTP up all of your files
2) export and import your database to the live server
3) update your connection file with the new database credentials
You can use the multiple connections interface to set up the live server as your remote server and use your local server for testing still. You just enter the domain in the additional connections dialog and the credentials to use for that domain.
