repeat bootstrap card
Thread began 2/22/2019 2:09 pm by Jonas | Last modified 2/23/2019 2:04 pm by Ray Borduin | 300 views | 1 replies |
Jonas
I rewrite and clarify my question. It's really the same problem as I wrotebefore. But here I explain it in a simpler way.
I want to show several cards from a database. This is no problem with repeat region. But the idea is that a modal should come up when you press a card. This does not work on the other cards, only on the first. Or rather, the information from the first card comes up instead of the card you have chosen.
What to do to make it work?
I'd need a URL to see what might be the issue. Somthing must be wrong in the javascript or in the html... but it is impossible to say without looking at it.
