logout / login redirect to previous page
After session times out you are logged out, when you log back in it directs you to //domain/favicon.ico instead of the previous page.
Any ideas?
Any ideas?
I'd have to look at the page. Can you attach a copy of your login page? There should be no difference between a session timeout and accessing the site directly without logging in in the first place.
What page were you on when your session timed out? Maybe the issue is with that page. What is the URL to your site? I may need FTP information to fully debug. I don't see any issues with the file you attached.
I can't spot the issue other than some blank lines in the file that could prevent the redirect. Can I get FTP access and a URL to view the page? I'll try to reproduce the problem and see if I can find a solution.
