getting an error when trying to add a MySQLi Recordset
Thread began 1/24/2019 7:48 am by Adam | Last modified 1/25/2019 9:01 am by Ray Borduin | 2182 views | 16 replies |
Adam
Just purchased and downloaded the MySQLi Server Behaviors, and I'm not able to insert a recordset due to the error message below. Any help would be greatly appreciated.
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'b64:U0VMRUNUICogRIJPTSBiYW5uZXIGT1JERVIgqlkgYHZpZXdgIEFTQw==' at line 1
Usually this is an issue with your site settings for your testing server URL pointing to the wrong directory. Can your export and send me your Dreamweaver site settings? I can use that to debug what might be wrong.
Adam
Here you go. Thank you again for your help.
It looks like you don't have a testing server defined? You need a testing server to connect to a database. I'll need the full exported site with the testing server and usernames and passwords to fully test. What is the url of your site? Make sure it is set correctly in the testing server settings and send me the full export so I can test if you still have issues.
Adam
Here's the full site. I don't recall needing to set one up in the past.
CMU2.ste
Adam
I'm having to migrate from php5.6 to php7...which is what prompted my purchase of the mysqli behaviors. everything has been working just fine, until i started migrating over to php7
It looks like your site is using the directory: www
but you don't have that specified in your remote and testing server settings. You will have to also move your Connections folder into that folder.
Dreamweaver has always required accurate testing server settings to connect to the database.
Adam
ok...here's an updated export. still getting that same error.
CMU3.ste
The root folder in your site settings is still set to: /
it should be set to: /www
and now your web url appears to be set incorrectly as well. It has to be the url to the site that you can copy and paste into a browser to view the pages.
Adam
here is the setup of another site i have...and everything works just fine on it currently (i haven't switched it to php7/mysqli, yet). do i need to set the cmu site root to /www even though i publish files outside the www folder?
other.ste
