44why can I not see global variables within a plugin file
Thread began 1/17/2019 5:13 pm by software.current355386 | Last modified 1/18/2019 11:09 am by Ray Borduin | 504 views | 6 replies |
I can set a session variable or a global variable like $kScreeenID, works fine but if try and retrieve the variable from within a framework plugin file it returns no value as it doesn't appear anywhere.
how can I correct this issue, any hep is greatly appreciated
It should be available. I'd have to see the page and context of how it is used to understand why it might not be working the way you would expect it to.
Logic appears to be working as expected .... the problem is the variable though specified if presenting it self as blank when in the goto page - THANK-YOU.php. this causing the default error message from a case test being displayed
I'd need FTP access and a URL to reproduce in order to debug this. I can't tell what would cause the issue is based on the information you have provided alone.
c PM
Your $kScreenREF variable is set on line 13 of the thank you page, but your template and code that uses it is loaded above starting on line 4.
I think you just have to move the code from line 13 up above line 4.
That worked
I think it would be wise to putting these at line 1 to avoid issues like this happening again
