CREATE UNIQUE INDEX FROM MULTIPLE DATABASE COLUMNS
Thread began 12/06/2018 12:17 am by software.current355386 | Last modified 12/06/2018 8:35 am by Ray Borduin | 647 views | 3 replies |
CAN ANYONE HELP ME WITH THIS ISSUE
HAVE DATABASE THAT HAS 2 NUMERIC FIELDS - RECORD NUMBERS FROM OTHER DATABASES, I WOULD LIKE TO COMBINE THESE TWO FIELDS TO PREVENT DUPLICATES
EXAMPLE
FIELD1 FIELD2 EFFECTIVE KEY
1000 66 100066
2000 900 2000900
1000 66 FAIL DUPLICATE KEY
OR IS THERE AN ALTERNATIVE SOLUTION.
You can add a recordset to the top of the insert page that looks up existing records based on the two key fields. Then you can use Server Validation to validate that the recordset doesn't return any rows to verify the keys aren't repeated.
any samples available
I don't have any samples, but this has been done many times before. Give it a try and post back with the file if you have any questions or issues. This is something I could help with in a premier support ticket during screen sharing if you would prefer.
