new html editor
Thread began 11/29/2018 5:43 am by Sweens | Last modified 12/05/2018 1:29 pm by Ray Borduin | 1487 views | 10 replies |
Sweens
new html editor
Hi Ray
Attached shows a couple of issues with the old (top) and new (bottom) html editor.
Having installed the one in the new databridge:
1) Some button icons have disappeared in the old editor
2) Image alignment isn't working in the new editor.
I'd also like to make the language based on a database value (en, fr, de etc) but don't seem able to do this now.
Cheers
Chris
Can I get FTP access and a URL to take a look? I'm not sure what could cause the issues offhand, but I'll look into it.
Sweens
Thanks Ray
I've fixed the image alignment issue by adding a body class. The buttons are also fixed.
I thought I'd fixed the language issue by adding
$CKEditor_config["contentsLanguage"] = "fr";
$CKEditor_config["language"] = "fr";
(with the 'fr' being dynamic) -but it isn't working now.
Do you still need ftp access?
Cheers
Chris
FTP access will help to debug your language issue. I can take a look and try to get that one fixed for you.
Sweens
pm
Try using:
$CKEditor_config["defaultLanguage"] = "fr";
Sweens
Hi Ray
Unfortunately, that makes no difference.
Cheers
Chris
The FTP information you provided isn't working for me. If I could get in then I could play around with it more to see what is going wrong.
Sweens
pm
Changing language seems to work fine on both pages.... the line you need to change is:
$CKEditor_config["language"] = "en";
I can change that to:
and it shows up in french after refreshing the page.
