Problem with 2 server validation behaviours on one page - need two different triggers but it's not validating the second instance
Thread began 11/22/2018 1:07 pm by Nathon Jones Web Design | Last modified 11/22/2018 7:14 pm by Ray Borduin | 72 views | 9 replies |
I have two Server Validations on one page as follows:
if (isset($_POST["btnADDSTEP1"]) || isset($_POST["btnADDSTEP1_x"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_healthscreeningform_984_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateAN(((isset($_POST["FirstName"]))?$_POST["FirstName"]:"") . "",true,true,false,true,"-",true,1);
$WAFV_Errors .= WAValidateAN(((isset($_POST["Surname"]))?$_POST["Surname"]:"") . "",true,true,false,true,"-",true,2);
$WAFV_Errors .= WAValidateAN(((isset($_POST["Address"]))?$_POST["Address"]:"") . "",true,true,true,true,"-",true,3);
$WAFV_Errors .= WAValidateAN(((isset($_POST["Address2"]))?$_POST["Address2"]:"") . "",true,true,true,true,"-",false,4);
$WAFV_Errors .= WAValidateAN(((isset($_POST["City"]))?$_POST["City"]:"") . "",true,true,false,true,"-",true,5);
$WAFV_Errors .= WAValidateNM(((isset($_POST["Country"]))?$_POST["Country"]:"") . "",202,450,0,",.",true,6);
$WAFV_Errors .= WAValidateAN(((isset($_POST["Postcode"]))?$_POST["Postcode"]:"") . "",true,true,true,true,"",true,8);
$WAFV_Errors .= WAValidateAN(((isset($_POST["Telephone"]))?$_POST["Telephone"]:"") . "",false,false,true,true,"-()#+",false,9);
$WAFV_Errors .= WAValidateAN(((isset($_POST["Mobile"]))?$_POST["Mobile"]:"") . "",false,false,true,true,"-()#+",false,10);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email"]))?$_POST["Email"]:"") . "",true,11);
$WAFV_Errors .= WAValidateLE(((isset($_POST["EmailConfirm"]))?$_POST["EmailConfirm"]:"") . "",((isset($_POST["Email"]))?$_POST["Email"]:"") . "",true,12);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"healthscreeningform_984");
if (isset($_POST["btnADDSTEP2"]) || isset($_POST["btnADDSTEP2_x"])) {
$_SESSION['WAVT_healthscreeningform_783_Errors'] = "";
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateAN(((isset($_POST["GPName"]))?$_POST["GPName"]:"") . "",true,true,false,true,"-'().",true,7);
PostResult($WAFV_Redirect,$WAFV_Errors,"healthscreeningform_783");
I won't add all of my form details but it's set up as follows...
<form name="formSTEP1" method="POST" action="">
<input type="text" class="form-control<?php
if (ValidatedField('healthscreeningform_984','healthscreeningform_984')) {
if ((strpos((",".ValidatedField("healthscreeningform_984","healthscreeningform_984").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
?> is-invalid<?php //WAFV_Conditional health-screening-form.php healthscreeningform_984(1:)
}?>" name="FirstName" id="FirstName" placeholder="First name" maxlength="30" value="<?php echo(ValidatedField("healthscreeningform_984","FirstName")) ?>" required>
if (!(false)) {
<small class="text-danger">Invalid number or character.</small>
<button type="submit" class="btn btn-info" name="btnADDSTEP1">Next <i class="fal fa-chevron-double-right"></i></button>
</form>
<form name="formSTEP2" method="POST" action="">
if (ValidatedField('healthscreeningform_783','healthscreeningform_783')) {
if ((strpos((",".ValidatedField("healthscreeningform_783","healthscreeningform_783").","), "," . "7" . ",") !== false || "7" == "")) {
if (!(false)) {
?> is-invalid<?php //WAFV_Conditional health-screening-form.php healthscreeningform_783(7:)
}?>" name="GPName" id="GPName" placeholder="Your GP's Name" maxlength="100" required>
if (!(false)) {
?><small class="text-danger">Please enter your GP's name.</small><?php //WAFV_Conditional health-screening-form.php healthscreeningform_783(7:)
<button type="submit" class="btn btn-info" name="btnADDSTEP2">Next <i class="fal fa-chevron-double-right"></i></button>
</form>
It's not validating the second instance of the behaviour (healthscreeningform_783).
Any idea what might be causing this?
Page attached for reference. Thank you.
Thank you.
NJ
Please describe what steps you go through and what happens as compared to what you expect would happen. The code is on the page, so you don't need to include that inline.
The information you gave me to go on is:
"It's not validating the second instance of the behaviour (healthscreeningform_783)".
You have two different forms on the page... are you expecting them to both submit at once? How are you expecting this to all work? You submit page 1 first? Then they click to go to page 2? I'm a bit confused. Do you have a url where I can view this. I need a better description of what you are trying to do here.
Please find a link to the form below. I'm trying to set it up using Bootstrap 4 nav tabs so that what is actually a very long form is more digestible - it being split into 5 sections (Steps 1-5) using the Bootstrap tabs. However, the form is entirely on one page.
I'm running into problems because of the following...
1) When a user completes Step 1 (the first form on the first tab), I am saving to database because the client wants the user to automatically receive login details so that should they only part complete the form, they can later return to it (it being saved and available in a user/pass protected area).
2) Once a user progresses past Step 1, I would prevent them from submitting Step 1 again, in this session, based on whether or not there was an instance of a newID session (created in the MySQLi Insert behaviour).
3) So, Step 1 is validating (healthscreeningform_984) and submitting to database correctly. I have not implemented it yet, but I will be doing an insert to multiple tables at this stage - Customer, Order and Order Detail
4) At this stage it progresses you to Step 2 which I have only set up one validation on so far (GP's Name). It is this validation (healthscreeningform_783) that's not working.
As well as setting up validation on the forms within each Step I also need, at the end of each step, to run an UPDATE behaviour on the Order Detail table (basically the entire form data from Steps 2-5).
Hope that makes sense. If you feel there is an easier way to approach this, I'm all ears btw!
Thank you Ray.
NJ
PS. Are you back from sailing?
I'll need FTP access to debug this. I'm not quite sure what is going on.
I'm still in the Bahamas in the bay of an uninhabited island, but I have cell service so I can work a little.
Thank you Ray. FTP details below, if you have the time. A bay of an uninhabited island in the Bahamas sounds like just what I need...permanently!
I can't seem to get in with that FTP information. Please verify that there are no typos and that there isn't any IP restrictions that would prevent my access.
No typos. Just double checked it there. You're including the exclamation mark in the password, right?
No IP restrictions either.
I'm not sure why I can't get in then. I'm copying and pasting from your message, so it can't be a typo on my end.
I get this error in FileZilla:
Response: 425 Sorry, invalid address given
I'll need to access your files in order to debug this issue. Do I need any additional ftp settings I might be missing?
Just cut and pasted the above FTP details into FileZilla and it's let me straight in.
Settings - no port specified. Encryption is 'Use explicit FTP over TLS if available'. Logon Type = Normal Server Type = Default (Autodetect)
I still can't connect. I wonder if it has something to do with my Bahamas IP address? I'm on vacation until December 6th.
