I am trying to set up a MySQLi Server Behaviors Dynamic List/Menu
Thread began 11/09/2018 7:25 am by anonymous | Last modified 11/12/2018 9:35 am by Ray Borduin | 230 views | 1 replies |
anonymous
My problem is when I am trying to do the step "Use the Select value equal to field and associated dynamic data button to set the value your list/menu will be by default when the page loads." When I click on the "bind to dynamic source" it brings up the popup window to make the selections, but when I click on the record set, it doesn't do anything, it doesn't display a list of fields to pick from, it just does a spinning blue circle next to my pointer for a second and than does nothing. I have attached two images to show as far as I can progress. Anyone know what I'm doing wrong? or what could be causing this issue?
I'm unable to reproduce this problem. It could be the DW version you have installed. This was an issue in a previous version that Adobe has addressed in a recent update. Use Adobe Creative Cloud to update Dreamweaver to the latest version and this issue should be resolved.
