Another Strange One
Another one that throws some SQL code and then the error: "Truncated incorrect INTEGER value:"
You have this in your url:
contact[]=+
The '+' ia space. This means you are passing in a space character where you should have a number. The code is recognizing this and returning the error.
I updated the rsobj.php file to ignore mismatched values in searches specifically, which fixes the page as you have it, but another solution would have been to make sure you aren't passing in a space for a number search value.
