Error on Creating Database
Thread began 10/22/2018 11:39 pm by Juan | Last modified 10/23/2018 5:17 pm by Ray Borduin | 66 views | 3 replies |
Juan
Hi the extension generates an error when you click on the magnify glass icon. See attachments. I test in 3 different sites and the same. Also I create a new site and is the same error.
Regards
You have to select a table below before you can use the magnifying glass. I'll update the extension to disable that button when it isn't applicable, but that is why you are getting the first error.
The second error implies that the _mmServerScripts haven't been updated to the latest version. Try going to Site->Advanced->Remove connection scripts and then try again. If that doesn't work, you may need to reinstall the extension to get the proper version of the connection scripts. It is possible it was overwritten when installing another extension.
Juan
I delete MSQLi Extension and only leave the data bridge 2 extension. I donĀ“t know if is something in MSQLi different than Data Bridge 2 ??
And yes I notice that this error only happen when the connection or no table is selected. If you select a table it works perfect. Its a good idea to disable button.
I'll get it disabled in the next update. I replied to your email as well.
