Is this a bug!
Thread began 10/02/2018 2:36 pm by mrs | Last modified 10/04/2018 5:51 pm by Ray Borduin | 616 views | 2 replies |
mrs
Is this a bug!
Hi Ray, I have just run the data assist wizard and got the pages I required, but I just noticed the two of the lines seemed to be potentially missing something:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
Should these not have https: in front of the //?
The page seems to work fine either with or without the https:!
Just wondering if it might cause an issue somewhere that I haven't yet come across.
No, this is by design. If you start a link with "//" then it will use http:// when your page uses http:// and https:// when your page uses https://. This prevents errors when someone is using SSL and prevents unnecessary overhead when it isn't.
mrs
Ooo... I did not know that! Thanks for explaining.
