Errors when using send email
Thread began 9/29/2018 9:04 pm by mrs | Last modified 10/01/2018 6:41 pm by Ray Borduin | 68 views | 4 replies |
mrs
Hi Ray, I have used the Send Email function several times before on the beta, but I have just tested the latest version several times and I keep getting the same error messages pop up. I've attached the screen shots of the messages, but it's after I have clicked OK and the code is being produced.
Image 1 pops up first followed instantly by 2, so I OK 2 and then OK 1 and the code is created
mrs
Just including code for you too, but privately...
The code works fine and sends emails, but I did initially try to have an upload file field so I could send an attachment however the attachments didn't come through as attached files via email when I've used the block email template.
I have tried to add the Send Email function numerous times and basically decided to delete the email folder from the webassist folder just to get back to a clean starting point again. I expected to not see the error messages again once I decided to no longer send attachments, but they're still appearing.
It's not causing me issues by the look of it, but I thought I'd share with you, just in case.
Thanks.
Please install the latest version. I think I have this issue fixed.
mrs
Have you updated it since 9 September, then? I'm just wondering because the version number is the same as what I have installed already, and the file size of the downloaded file is the same too.
Have you just not iterated the version number? The version I have installed is listed as 2.2.0, and the version I have just downloaded is also 2.2.0.
Thanks Ray
Yes... I didn't iterate the version number. That takes time and effort that during the BETA I don't always make.
