Security Assist Issue
Thread began 9/20/2018 2:26 pm by Dave Buchholz | Last modified 9/21/2018 1:51 pm by Ray Borduin | 150 views | 2 replies |
Dave BuchholzBeta Tester
I have a problem with a site not allowing login with a valid username and password despite the fact it works perfectly on my local server. is their a minimum PHP level ? The server is on 5.3.29 my local server is 5.6.30 ?
Server Access Details below:
Your live server has a bad php.ini setting for session_save_path. It is either a non-existent directory or it doesn't have adequate privileges, so session variables can't be set and so login won't work.
I created a set of test pages to demonstrate the problem:
http://www.nationwidejustsayyes.com/admin/setSession.php
You can forward that to your hosting provider and they should be able to fix it for you.
Many thanks Ray I will forward that to them now, much appreciated.
