Bug in the add variable panel
Thread began 9/19/2018 8:22 am by María Luisa | Last modified 9/19/2018 9:44 am by Ray Borduin | 312 views | 1 replies |
María Luisa
I want to introduce a variable in the WA Recordset panel just as it did in my old server behaviors panel of Dreamweaver and it looks absolutely strange and ineditable: Where can I put the name of the variable, or the type of data, or its value in runtime, etc?
My Dreamweaver is CS6
I attach an image and I need an answer. Thank you very much
This is probably a foreign language issue. The larger labels cause the interface to not fit on the screen. We only officially support the english language version of Dreamweaver. I can look into options on how to fix this issue.
A solution that might work for now is to use the Data Bridge BETA linked from the top of this website. It will allow you to use the standard recordset dialog to create mysqli recordsets. That uses the native Dreamweaver dialog windows which have foreign language support.
