CSS Menu Writer Version
DZW Updater says CSS menu writer 1.0.3 is available, but I already have version 2.2
Are we being downgraded?
after checking download details it says there is still ver 2.0.2 available.
I guess I should have had more coffee before I sat down in front of my computer...
I saw the same notice - but I thought it may have to do with the fact the I bought CSS Menu Writer a few months back, but bought the Dynamic Suite (which also has the Menu Writer) a few weeks ago. I have also upgraded to CS4 since originally installing CSS Menu Writer, so I figured it wouldn't hurt to re-install the Menu Writer extension.
Now when I go into Dreamweaver, I get two error messages:
#1 - While executing onLoad in CSSMenuWriter.htm, the following JavaScript error(s) occurred: In file "CSSMenuWriter": onStartup not defined. (then a click OK button).
After clicking OK, I get:
#2 - While executing onLoad in WAManager.htm, the following JavaScript error(s) occurred: In file "WAManager": onStartup not defined. (then a click OK button).
I went ahead and made a temporarily in Dreamweaver and ran the Menu Writer wizard. It seems to work okay, but I don't want to have to see those errors every time I go into Dreamweaver...
Can you help?
Regards,
Julie
aka Fergie
Have you tried deleting your filecache .dat file? That is often the cause of odd errors like this:
showthread.php?t=3977
