ecart
I need to update to the latest eCart. What is the newest version of Dreamweaver I can use with the new version of eCart. By default I am using Dreamweaver 20188cc...I am guessing I need to install an earlier version though?
Please advise.
Please advise.
The latest version of eCart works with the latest version of Dreamweaver.
I'm looking in to this because I am getting the following errors using PHP7
[29-Aug-2018 13:49:51 UTC] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCart_Rule has a deprecated constructor in /home/directbe/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 4
[29-Aug-2018 13:49:51 UTC] PHP Deprecated: Methods with the same name as their class will not be constructors in a future version of PHP; WA_eCartDisplayCSSLooper has a deprecated constructor in /home/directbe/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 1000
Maybe I can just update the code to fix it if you can give me an idea?
Thanks Ray
If you update to the latest version of eCart and open and update the eCart object, this code should be updated to fix this warning.
OK. Just in case someone else has this issue.
So, I had installed previously a the server panel (from adobe exchange), I think this might have been messing with the set up. I removed this and reinstalled eCart (6.1.2) to Dreamweaver 2018cc (18.2) and did so with DMXZone Extension Manager and all is now working as expected.
I do not know why the installation of the server panel from Adobe Exchange could do this, but removing it did the trick for me. Maybe it can do the same for someone else.
