Search Results Empty
These results used to work and stopped working.
You must be searching with the wrong columns or wrong values.
I added this to line 352:
echo($WADAtimes->debugSQL());
That will write the resulting SQL statement that you can probably use to see what columns are searched with what values and you can run the sql in PHPMyAdmin to figure out what you might have wrong.
