These things are driving me nuts, dynamic list, different page
This one was working as well and is now showing wrong results...
You must be filtering the child recordset with the wrong value or using the wrong column.
Your parent select uses the column: customers_id
That gets passed to the child select list where you use it to filter the column: customers_address_book.id
My guess is that you should be filtering that plugin with the column: customers_address_book.customer_id
