I have no idea if this is the correct forum to post to or not
Do I need to use Dataassist to alway create an update or insert form ? If not what should I use to create those 2 things
You can create it however you want. You can create the form by hand in html, or use form builder, or take a form you find on the web that you like.
Then you can apply the insert or update server behavior.
A shortcut is to use the Database->DataAssist Pages wizard to quickly build Search, Results, Insert, Update and Details pages, but it isn't necessary.
