500 error again
Thread began 6/04/2018 4:09 pm by vernon webb | Last modified 6/05/2018 6:38 pm by Ray Borduin | 146 views | 7 replies |
vernon webb
500 error again
this page has some upload stuff, I'm not sure if that is support or is related to the error
It seems to be the same issue when updating insert and update server behaviors from a previous version. I fixed the page. Do you have a copy of the original before you updated to mysqli? I'd like to take a look to use while I try to fix the issue.
vernon webb
The attached is the original which is on the live site with no edits at all.
vernon webb
Man I just overwrote the file and it's not working again, could you please re-upload?
I re-uploaded. I was able to find and fix the problem using the sample file you sent. I'll get a new build out later today so that this doesn't keep happening when updating Insert Record server behaviors to mySQLi.
vernon webb
The delete function is giving me a that has to do with the Insert function. If you try to delete the M21581-angle-xlarge.jpg you will see the error.
You had an "any form post" trigger for the insert, so it was triggering on delete as well. I updated your delete trigger to use the delete button and your insert trigger to use the insert button and that seems to have fixed it.
vernon webb
Some stuff must get removed when I update the other stuff as all these pages worked previously, obviously.
