Update Not Working
I get errors in regards to the date on this page.
Date Fields can't have blank values. Set the default to NULL instead of blank for that column when no value is present. In the code you can replace WA_BLANK with WA_NIULL, or in the interface select that column binding and change the default in the select list to "null".
