Serious Pain in the You Know What
Thread began 5/30/2018 9:13 am by vernon webb | Last modified 5/31/2018 10:26 am by Ray Borduin | 534 views | 3 replies |
vernon webb
So if I go in an edit a recordset, it deletes the connection string as I have renamed the connection string from connIO to connIO_i this way I know that it has been updated. When I do this however it deletes the connIO from the file and when I try to update the insert or update behavior it causes Dreamweaver to tell me it doesn't exist. So I go and manually copy the connIO_i and rename it only to have Dreamweaver hang for quite some time
I'll look into getting that fixed in the next release. Does it work better if you update the inserts and updates first?
vernon webb
Just tried it and it still deletes the connIO, which is easy enough to copy over, but that dialog box (Loading database schema, or whatever it says) sits there for ever until I finally just canceled it out. It does "seem" easier...
I'll log the issue and try to make it so the connection doesn't get replaced while it is in use by other server behaviors before the live release.
