HTML editor stripping all inline styles
Dear sir, Madam
Excuse me for my bad English...
I have a problem, when I click update page there are no inline css.
Please look at the attachment
Best regards Ivica
Dear sir, Madam
Best regards Ivica
Do you have magicquotesgpc enabled on your server? That could explain this issue. If you post a url where I can reproduce the problem and give me FTP access I can debug and let you know for sure. Most likely you just have to disable magicquotesgpc in your php.ini file.
Hi Ray,
I created php page using a mySQLi connection, but on the page is showing HTML tags as text please can you help?
FTP is in PM
Please attach the page you are working on and I can show you what to update. The issue is that MySQLi has built in Cross Site Scripting protection. That can be turned off when you populate the editor or display the content from that field. You just have to add a "false" argument to the end of your ->getColumnVal() reference to tell it to not encode the html elements.
