how to calculate the total and post the result into the database
Thread began 3/20/2018 12:42 am by Jeff | Last modified 3/22/2018 9:56 am by Ray Borduin | 762 views | 4 replies |
Jeff
i have a form with 5 fields, date, tithe, offering, seed and total. but i have removed the total field because i want user to enter data on the tithe, offering and seed once the user clicks add, the data will be posted in the database and automatically the total will be also calculated and posted into the database on the total column
You can do math in php. So you can use a binding like:
<?php echo($_POST["offering"] * $_POST["tithe"]); ?>
Jeff
Hi Ray thanks for the quick reply.
According to this php binding will the result be posted into the database or will it be display on the page.
What I want is the result to be posted into the mysql database directly
Yes, just use that as the column value in the insert record server behavior.
Jeff
Hi Ray
Thank you so much God bless you, Its working now.
