Plugin not Showing in a Framework Page
Thread begun 2/12/2018 1:39 pm by Mike Perry | Last modified 2/13/2018 9:46 am by Ray Borduin | 2624 views | 6 replies |
Mike Perry
DW CS6, Latest WA extensions, Windows 10 (current).
Framework page displays fine. Template file has a FW plugin (a top navigation php file) that displays properly. The second FW plugin in he FW page is a side nav php file. I can see it in the preview in DW; when I go to live code it disappears, and the placeholder text displays.
I can remove the top nav from the template and insert it into the FW page and the same thing happens.
I tried switching PHP versions in Wampserver to 5.6.1.31; no joy.
If I insert the two navs php fils via Framework Builder Plugin into a new page from the template they display fine. If I just have the side nav php inserted via Plugin with the Framework page it does not display. So it appears to be a conflict between the Framework page code and the side nav php file.
All php nav files were created with CSS Menu Writer
Thanks,
I'd need a url and FTP access to debug this.
Mike Perry
See PM
That ftp information doesn't seem to work for me. Please test and make sure there are no typos or additional configuration settings I might need.
Mike Perry
typo -- correction in PM
ETA: Neither nav is showing online -- and there is an extraneous </div> after the UserMainNav div. . .
You have the usermainnav.php plugin on both the page and the template. That was causing conflicts.
The larger issue was in your template. You had:
<!--TemplateBeginEditable name="sideNav" -->
as small as it may seem it has to be:
<!-- TemplateBeginEditable name="sideNav" -->
The missing space in the template editable region declaration was causing it to not be found.
I've corrected both issues, so you can see your page is working now.
Mike Perry
Got it -- thanks a bunch Ray!!!
