database connection not working
Thread began 1/29/2018 2:57 am by Jamie | Last modified 1/30/2018 8:38 am by Ray Borduin | 1053 views | 2 replies |
Jamie
Hi Ray
Just migrating a site from test server to live and getting the following error:
Notice: Undefined variable: H in /home/ebcllp/public_html/Connections/PowerCMSConnection.php on line 33
Warning: mysql_pconnect(): Access denied for user 'ebcllp_admin'@'localhost' (using password: YES) in /home/ebcllp/public_html/Connections/PowerCMSConnection.php on line 39
Fatal error: Access denied for user 'ebcllp_admin'@'localhost' (using password: YES) in /home/ebcllp/public_html/Connections/PowerCMSConnection.php on line 39
The connection file (attached) has got the exact same username, database and password as the DB admin tool I use (HeidiSQL) and Heidi connects without any problems whatsoever.
The domain is parked at a 3rd party and the A record is being pointed to my server - could that be affecting it? Other than that am unsure what else could be causing this problem?
Cheers
Jamie
It is the dollar sign in the connection. I think if you add a backslash before the dollar sign it will work properly. Another solution would be to use single quotes instead of double quotes for the string with the dollar sign.
Jamie
thanks Ray...escaping the $ did the trick
