add a condition before query is executed
Thread began 12/04/2017 1:03 am by Neville | Last modified 12/11/2017 7:57 am by Ray Borduin | 1903 views | 3 replies |
Neville
i want to make sure that the balance in account is sufficient before mysqli insert query is executed. i want to compare amount from form to available balance.
<?php require_once('Connections/transaction.php'); ?>
<?php require_once('webassist/mysqli/queryobj.php'); ?>
$amt = $_POST['debit'];
$bal = "SELECT (SUM(credit) - SUM(debit)) AS balance FROM transaction WHERE account_no = '".$_SESSION['account_no']."' ";
if($debit < $bal) {
header('Location:TransferFund.php?amount=insufficient' ));
exit();
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$InsertQuery = new WA_MySQLi_Query($XtremBANK_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "`transaction`";
$InsertQuery->bindColumn("account_no", "i", "".$_SESSION['account_no'] ."", "WA_DEFAULT");
$InsertQuery->bindColumn("trans_date", "t", "", "WA_CURRENT_TIMESTAMP");
$InsertQuery->bindColumn("reference", "s", "".((isset($_POST["reference"]))?$_POST["reference"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("credit", "s", "0.00", "WA_DEFAULT");
$InsertQuery->bindColumn("debit", "s", "".((isset($_POST["debit"]))?$_POST["debit"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("beneficiary_id", "i", "".((isset($_POST["beneficiary_id"]))?$_POST["beneficiary_id"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("trans_type", "s", "".((isset($_POST["trans_type"]))?$_POST["trans_type"]:"") ."", "WA_DEFAULT");
$InsertQuery->bindColumn("status", "s", "".((isset($_POST["status"]))?$_POST["status"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "../../success.php";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
You will need to create a recordset to return the balance. Then you can compare the returned value from that recordset to the posted amount.
Neville
did as you said but the update still isnt working
<?php require_once('../../Connections/XtremBANK_i.php'); ?>
<?php require_once('../../webassist/mysqli/rsobj.php'); ?>
<?php require_once('../../webassist/mysqli/queryobj.php'); ?>
$rsChangePassword = new WA_MySQLi_RS("rsChangePassword",$XtremBANK_i,1);
$rsChangePassword->setQuery("SELECT * FROM customer WHERE account_no = ?");
$rsChangePassword->bindParam("i", "".$_SESSION['account_no'] ."", "-1"); //colname
$rsChangePassword->execute();
if (isset($_POST['currentPassword']) != $rsChangePassword->getColumnVal("password")) {
header('Location:ChangePassword.php?change=unsuccessful');
exit();
$UpdateQuery = new WA_MySQLi_Query($XtremBANK_i);
$UpdateQuery->Action = "update";
$UpdateQuery->Table = "customer";
$UpdateQuery->bindColumn("password", "s", "".((isset($_POST["confirmPassword"]))?$_POST["confirmPassword"]:"") ."", "WA_DEFAULT");
$UpdateQuery->addFilter("customer_id", "=", "i", "".($rsChangePassword->getColumnVal("password")) ."");
$UpdateQuery->execute();
$UpdateGoTo = "ChangePassword.php?change=successful";
if (function_exists("rel2abs")) $UpdateGoTo = $UpdateGoTo?rel2abs($UpdateGoTo,dirname(__FILE__)):"";
$UpdateQuery->redirect($UpdateGoTo);
I'd have to debug it. First I'd see if the recordset returns any results. Maybe the session isn't started or saved properly.
