form validation
Thread began 11/12/2017 12:13 pm by Nebras | Last modified 12/11/2017 8:01 am by Ray Borduin | 2704 views | 15 replies |
Nebras
form validation
Hello
I create a log-in system using webassist security pages. The system was created but I could not use it at hostgator because the code is old. Then I start changing the code to mysqli. I have problem in the Registration page. The error is in file that is created by webassist, I did not change anything in it. When I create a user I got an error at line 32. When I write an email address that already is in the database I got an error at line 85. The tow error message I get is addressed below. Can you please help with this.
Warning: mysql_select_db() expects parameter 2 to be resource, object given in /home3/kibo/public_html/webassist/form_validations/wavt_scripts_php.php on line 651
Warning: Cannot modify header information - headers already sent by (output started at /home3/kibo/public_html/webassist/form_validations/wavt_scripts_php.php:651) in /home3/kibo/public_html/webassist/mysqli/queryobj.php on line 32
Warning: Cannot modify header information - headers already sent by (output started at /home3/kibo/public_html/webassist/form_validations/wavt_scripts_php.php:651) in /home3/kibo/public_html/webassist/form_validations/wavt_scripts_php.php on line 85
An other, question, how much a ticket for inserting multiple record using mysqli cost?
I can help with a multiple update in a singe premier support ticket.
The error you are getting is because you are still doing a "unique email validation" check in the Server Validation server behavior on the page using the old mySQL connection. That has already been updated to allow you to use a MySQLi connection, so you would just have to open and edit that validation and select the MySQLi connection to update the code.
Nebras
hi. Thanks for reply Ray.
I did change the connection to mysqli but it did not help. I attached a screenshot of the server behavior and mysqli connections file. BS: the page works fine when I remove unique email validation
Have you downloaded and installed the latest version of DataBridge and uploaded the latest validation include file? That file was updated to fix issues.
If you send me FTP access in the private area and a live url where I can view the problem I can take a look.
Nebras
please see the private section
It looks like an older version of wavt_scripts_php.php was accidentally included in the latest build. I've corrected the problem on your web site as well as in the download. If you reinstall Data Bridge it shouldn't happen in the future.
Nebras
please see the private message
I think we could probably get through all of your issues in 2-3 hours, but it is hard to say. The email deliver-ability one can be tricky. Some of the issues are simple to fix like the missing css after a mod rewrite. I'd start by signing up for an hour and see how much we can do.
Nebras
please the private message
Just sign up for a premier support ticket and I'll give you a call to schedule a time. I invoice and collect payment after the session.
