Unable to connect to server: error message "An unidentified error has occurred"
Hello,
I just installed mysqli server behaviors extension. When I tried to connect to the MAMP server, I get the following error "An unidentified error has occurred".
Hello,
This is usually an issue with the server settings. More specifically the testing server Site URL setting. I'd have to see your testing server settings to debug. Have you made sure your MAMP server is running and you are able to connect to phpMyAdmin?
