Need to activate Security Assist 2.0
I cannot find this in my list of products. Please advise.
Security Assist is now part of Data Bridge. You should be able to install that and use the DataBridge serial for activation.
I have done this to no avail.
Data Assist is registered.
When I open Security Assist it is asking for a Security Assist serial number
You must have also installed SecurityAssist afterward. You should only have Data Bridge installed. Try reinstalling DataBridge.
Wait. Data Bridge will not support ASP.
This is an ASP site. I need Security Assist 2.0.
I own it, why can I not register it?
You are correct, we dropped ASP support about ten years ago. You don't seem to own Security Assist 2.0. Our records show you got a refund for it after purchasing and then purchased Data Bridge instead.
You do seem to own SecurityAssist v1.0, which should work for ASP on a very old version of Dreamweaver.
That would explain it. Now that you mention it I recall feeling that there was nothing in Security Assist 2.0 that I wanted and that 1.0 did everything I needed. I will delete the 2.0 install file that I have and install 1.0. I am sure it will do what I need.
Thank you and sorry for the bother.
