Delete a single record
I have problem to delete a record from database. I surfed your site as well as other sites but no success; the result is a blank page with no deletion action.
It looks like it would work from here. I'd need FTP access and a URL to reproduce to fully debug what is wrong.
I use it as localhost and not sure how to manage FTP access in this situation.
I think I see the problem. You are using an "any form post" trigger for the delete server behavior, but you aren't submitting to the page. You can probably update that to use "before page load" or trigger off the specific url parameter.
Hi Ray,
You are right. Your recommendation resolves my problem. Many thanks for your prompt response.
