Update Cart error: Clears entire page
After installing a new shopping cart, the Update Cart function is broken - it appears to blow away the entire page. How do I fix this?
I'd have to see the page. If you updated eCart versions you would have to re-create the cart object and it would add the update cart button. The update cart button is only for use on a cart display page.
