limiting file upload to only pdf's
Thread began 8/10/2017 5:27 am by Jamie | Last modified 8/18/2017 10:49 am by Ray Borduin | 1126 views | 6 replies |
Jamie
Hey Ray
On the attached page, am trying to limit the field SampleMenu to fail if anything other than a pdf file is uploaded.
I cant seem to get that to work and not sure if my regex expression is correct within the server validations:
$WAFV_Errors .= WAValidateRX($row_WADApage_contents['SampleMenu'] . "","^(([a-zA-Z]:)|(\\{2}\w+)\$?)(\\(\w[\w].*))(.pdf|.PDF)$",false,11);
Jamie
You are validating a row from a recordset in this code. You should be validating the name of the file uploaded. You should be able to get the file name or even the file extension from the bindings panel and use that to do your validation.
Jamie
cheers Ray
Have done that (see attached) but its still allowing anything to be uploaded even though I specified .pdf in the server validation
It won't be able to stop the upload, it would just stop the update or insert after the upload. You would have to use client validation to stop the upload in the first place.
Jamie
would I do that with a WA extension or do I need to find some js to achieve this?
Actually I misspoke. It will automatically upload, but it shouldn't transfer the file to the destination directory. It would remain in the tmp directory and be removed later. Is the file being uploaded to the destination directory? It looks like it would work to me.
Actually I think I see it. The value you should be using should be from the FORM bindings, not the UploadFileField bindings. That wouldn't be available until after the webassist upload code runs.
Jamie
many thanks
took a few attempts as I started off binding against the form SampleMenu Extension and then tried Simple File Name - neither worked
Then I tried SampleMenu only and it works a treat
Jamie
