Error message
I get the attached error as a result from Power CMS. What is causing it?
It looks like I had left some debug code behind when fixing another issue. You can just ignore that message. I've just updated the extension, so if you reinstall Design Extender the alert should go away.
Thank you Ray. I see the latest version is July 7, 2015. Is this the one?
Yes. I didn't update the version or update date since all I did was remove the alert.
