Add to Cart buttons
Thread began 6/12/2017 5:53 am by elewis93815 | Last modified 6/12/2017 6:00 pm by Ray Borduin | 3301 views | 5 replies |
elewis93815
Add to Cart buttons
We've created a site / cart (www.yastylus.com) quite some time ago and just recently discovered that two of the 9 products listed, are giving an error when attempting to "add to cart" When you add another product to the cart, you will see that the product I attempted to add and received an error, actually added to the cart. Can you help me understand what is happening and please guide me to a resolution?
WA YA server behaviors.zip
You have a typo in the code.
order_dsiplay.php
should be:
order_display.php
a simple find and replace on the page should solve it.
elewis93815
Thanks, we were able to correct the spelling error and resolved the issue.
Side note, we are not able to get to "Server Behaviors" to even look at the button credentials, getting an error. The second error pops up when we try to open the "cart" on this site.
While executing findServerBehaviors in a WA eCart 01Object.htm, a Java Script error occurred.
While executing onClick in WA_eCart_Floater.htm, the following JavaScript error(s) occurred:
At line 79 of file "Macintosh HD:Users:elhomefolder:Library:Application
Support:Adobe:Dreamweaver CC
2017:en_US:Configuration:Shared:WebAssist:eCart:WA eCart Shared.js";
wa.pickDLL is not a function
What version of eCart? You would need eCart 6 to run on CC versions of Dreamweaver. Try installing the latest version and I think this error will be resolved. (reinstall if you already have the latest version, it is possible you have an older version of some key files)
elewis93815
We do have eCart 6. Any other thoughts? We'll try re installing and see what happens! Thanks so much for taking a minute to take a look!
Let me know if you still have issues after a reinstall and I can set up screen sharing to debug and get it fixed.
